Solved Issue with receiving calls from a DDI to IVR
Bruce Smith
Hi all, having a issue with a DDI/DID not accepting calls, if i call the number it comes up as engaged, the routes are in place they point to an IVR, Here is a Snip from my log what am I missing?
14/07/2021 09:10:53 - Leg L:2533.1[EndCall:EndCall] is terminated: Cause: BYE from PBX
14/07/2021 09:10:53 - Terminated from "07000000099" <sip:[email protected]..131>;tag=as73ac4cd4 to <sip:[email protected].220:5060>;tag=9f14cb75; reason: Rejected
14/07/2021 09:10:53 - L:2533.1[EndCall:EndCall] Sending: OnSendResp Send 403/INVITE from 0.0.0.0:0 tid=7ad198d7 Call-ID=[email protected]..131:5060:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP xx.xx.xxx..131:5060;branch=z9hG4bK7ad198d7;rport=5060
To: <sip:[email protected].220:5060>;tag=9f14cb75
From: "07000000099" <sip:[email protected]..131>;tag=as73ac4cd4
Call-ID: [email protected]..131:5060
CSeq: 102 INVITE
Warning: 499 BMWDC3CX01 "Caller is not identified"
Content-Length: 0
14/07/2021 09:10:53 - SendMsg from <sip:[email protected].220:5060>;tag=9f14cb75 to "07000000099" <sip:[email protected]..131>;tag=as73ac4cd4
14/07/2021 09:10:53 - Remote SDP is set for leg L:2533.1[EndCall:EndCall]
14/07/2021 09:10:53 - Source identification failed: Caller is not identified
14/07/2021 09:10:53 - [CM503013]: Call(C:2533): Incoming call rejected, caller is unknown; msg=Invite-IN Recv Req INVITE from xx.xx.xxx..131:5060 tid=7ad198d7 Call-ID=[email protected]..131:5060:
INVITE sip:[email protected].220:5060 SIP/2.0
Max-Forwards: 70
Contact: <sip:[email protected]..131:5060>
CSeq: 102 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Content-Type: application/sdp
Date: Wed, 14 Jul 2021 08:10:53 GMT
Supported: replaces
User-Agent: UCRESELLER MERLINDC22S
Content-Length: 323
v=0
o=root 287018320 287018320 IN IP4 xx.xx.xxx..131
s=Asterisk PBX 13.38.0
c=IN IP4 xx.xx.xxx..131
t=0 0
m=audio 15876 RTP/AVP 8 0 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
14/07/2021 09:10:53 - Call(C:2533) is terminated
14/07/2021 09:10:53 - Failed to identify source: several trunks matched by DID only. SI-Err Recv Req INVITE from xx.xx.xxx..131:5060 tid=7ad198d7 Call-ID=[email protected]..131:5060:
Max-Forwards: 70
CSeq: 102 INVITE
Supported: replaces
Content-Length: 323
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
14/07/2021 09:10:53 - More than one line have matched by DID only
14/07/2021 09:10:53 - Trunk Lc:10001(@Snodland_Backup[<sip:[email protected]:5060/UDP>]) has matched as source by DID only
14/07/2021 09:10:53 - Trunk Lc:10000(@Snodland[<sip:[email protected]:5060/UDP>]) has matched as source by DID only
14/07/2021 09:10:53 - IncomingCall: C:2533 from <sip:[email protected]..131:0/UDP> to <sip:[email protected].220:5060/UDP>
14/07/2021 09:10:53 - Added leg L:C:2533.1[No endpoint yet]
14/07/2021 09:10:53 - Call from "07000000099" <sip:[email protected]..131>;tag=as73ac4cd4 to <sip:[email protected].220:5060>;tag=9f14cb75
14/07/2021 09:10:53 - The SIP request source identification procedure matches several trunks by DID onlySI-Err Recv Req INVITE from xx.xx.xxx..131:5060 tid=7ad198d7 Call-ID=[email protected]..131:5060:
Max-Forwards: 70
CSeq: 102 INVITE
Supported: replaces
Content-Length: 323
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
I think your problem is this:
Code:
14/07/2021 09:10:53 - Failed to identify source: several trunks matched by DID only. SI-Err Recv Req INVITE from xx.xx.xxx..131:5060 tid=7ad198d7 [email protected]:5060:
Have you created multiple Trunks and entered the 443000000046 DID number more than once?
Make sure each DID exists only once on the system.
Hi, I have a backup trunk with the number in as well, i take it you can not do that.
Reactions: NickD_3CX
devo.it
