Issue with Voicemail Indicator after v20 Update 7
mic03167
I think we found a bug with the new version Version 20.0 Update 7 (Build 1057 Release).
Any user regardless of phone type (t46u, t33g, t54w, old polycoms) is getting the voicemail indicator set if they get a voicemail. We forward all voicemails and delete from inbox so the indicator should never be set. It was fine before update 7 and started after people started getting voicemails after the update.
I can clear it by disabling the voicemail forward/delete, then leave a message, then go into the phones mailbox and delete the message. Once I set it back to forward/delete then they get another voicemail it is back on again and cannot be removed.
Reactions: KyriacosS_3CX
Thank you for the update. I was not able to find it in the forum.
Syedx91
