issue with whatsapp
JulianB123
New User
We are also getting error code:
01/09/2023 8:44:22 AM - Lc:10004(@WhatsApp[<sip:@:0/UDP>]) has invalid configuration: primary target is empty
What can we do with this to get it working?
I would recommend recreating the integration in case you missed a step. If you follow the steps correctly then it should work like it works in your other systems.
If the issue persists, remember to make sure that the number is in International Format in the 3CX System WhatsApp configuration.
Example:
US: +11234567890
UK: +447975777666
NortechTelecom
