Solved Issues after recent upgrade
Shane Farmer
Not exactly sure when this started as I haven't been in console in a while. Pretty obvious what the issue is...
EDIT: Refreshing page fixed it for now. Not sure what was going on. Also started having some issues with making calls, but checking with upstream provider.
Version 20.0 Update 7 (Build 1060 Release)
At the moment there is still this issue or browser cache fixed it?
As for the sip trunk you might also need to check this with the provider or on your network.
Refreshing the page cleared it up the visual GUI, so that seems to be fine. The trunk provider said something upstream from his had issues. Someone else called besides us seeing the same thing. So just coincidental.
