Issues With apple MFA, calls inbound dont show the correct DID in SIP field
starr
Platinum Partner
first came up, that Apple is calling the IT line of the customer and these calls are getting rejected as an Unidentified Incoming Call. Looking at the Pcap, I see that the Message header has the To: address as {number}@{IP} number is an unknown number, and so is the IP. We can let this pass, by adding the number into the DID of the trunk and it works, but I need to have the call identified by the "Request-URI User Part" which has the correct to number. The way this was explained form the SIP trunk support was that the number is a forwarded number.
If someone has the correct line I need to fix or add in the SIP template, that would be great!
this is my current setup
<field name="Source" custom="" parameter="ContactHost">$GWHostPort</field>
<field name="ParameterIn" custom="" parameter="ToUserPart">$CalledNum</field>
<field name="ParameterIn" custom="" parameter="FromDisplayName">$CallerName</field>
<field name="ParameterIn" custom="" parameter="FromUserPart">$CallerNum</field>
<field name="ParameterOut" custom="" parameter="RemotePartyIDCallingPartyHostPart">$GWHostPort</field>
<field name="ParameterOut" custom="" parameter="RequestLineURIUser">$CalledNum</field>
<field name="ParameterOut" custom="" parameter="RequestLineURIHost">$GWHostPort</field>
<field name="ParameterOut" custom="" parameter="ContactUser">$OutboundCallerId</field>
<field name="ParameterOut" custom="" parameter="ContactHost">$ContactUri</field>
<field name="ParameterOut" custom="" parameter="ToDisplayName">$CalledName</field>
<field name="ParameterOut" custom="" parameter="ToUserPart">$CalledNum</field>
<field name="ParameterOut" custom="" parameter="ToHostPart">$GWHostPort</field>
<field name="ParameterOut" custom="" parameter="FromDisplayName">$CallerDispName</field>
<field name="ParameterOut" custom="" parameter="FromUserPart">$OutboundCallerId</field>
<field name="ParameterOut" custom="" parameter="FromHostPart">$GWHostPort</field>
<field name="ParameterOut" custom="" parameter="RemotePartyIDCallingPartyDisplayName">$OutboundCallerId</field>
<field name="ParameterOut" custom="" parameter="RemotePartyIDCallingPartyUserPart">$OutboundCallerId</field>
Is this via a supported SIP Trunk provider, using the appropriate build in template?
SG_F7
