- Joined
- Apr 27, 2024
- Messages
- 3
- Reaction score
- 0
I'm having issues with the scheduled backup 3cx does not seem to impress me as there is no support to reach anybody from the company or to even be able to successfully post on here without playing around with the system improve the support system because I'm sure as not spending $75 just for a simple solution to the problem I need to understand why this back up is not happening. I even gave my server a higher memory and I keep getting this message.
Your 3CX backup failed due to the following reason(s): System.IO.IOException: Entries cannot be created while previously created entries are still open. at System.IO.Compression.ZipArchive.AcquireArchiveStream(ZipArchiveEntry entry) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName, CompressionLevel compressionLevel) at System.IO.Compression.ZipArchive.DoCreateEntry(String entryName, Nullable`1 compressionLevel) at _3cxNetBackupAndRestore._3cxBackup.CreateEntry(String name) at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, IFile src) at _3cxNetBackupAndRestore.BackupTasks.BaseFilesTask.BackupFiles() System.IO.IOException: Entries cannot be created while previously created entries are still open. at System.IO.Compression.ZipArchive.AcquireArchiveStream(ZipArchiveEntry entry) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName) at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName, CompressionLevel compressionLevel) at System.IO.Compression.ZipArchive.DoCreateEntry(String entryName, Nullable`1 compressionLevel) at _3cxNetBackupAndRestore._3cxBackup.CreateEntry(String name) at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, IFile src) at _3cxNetBackupAndRestore.BackupTasks.BaseFilesTask.BackupFiles() System.IO.IOException: No space left on device : '/var/lib/3cxpbx/Instance1/Data/Backups/3CXScheduledBackup.zip.tmp' at System.IO.RandomAccess.WriteAtOffset(SafeFileHandle handle, ReadOnlySpan`1 buffer, Int64 fileOffset) at System.IO.Strategies.OSFileStreamStrategy.Write(ReadOnlySpan`1 buffer) at System.IO.Strategies.BufferedFileStreamStrategy.WriteSpan(ReadOnlySpan`1 source, ArraySegment`1 arraySegment) at System.IO.Compression.DeflateStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at System.IO.Compression.CheckSumAndSizeWriteStream.Dispose(Boolean disposing) at System.IO.Compression.ZipArchiveEntry.DirectToArchiveWriterStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at System.IO.Compression.ZipArchive.WriteFile() at System.IO.Compression.ZipArchive.Dispose(Boolean disposing) at System.IO.Compression.ZipArchive.Dispose() at _3cxNetBackupAndRestore._3cxBackup.FinishingTask()
