- Joined
- Sep 8, 2020
- Messages
- 179
- Reaction score
- 34
Hi together,
we have faced with an issue that an external caller press a key (3) in the ivr menu but an another extension will ring. In the ivr menu point 3 there is extension 22 but finally the 31 is ringing. Here is the logfile:
The IVR has joined:
11.03.2021 14:17:21 - [CM503007]: Call(C:2201): Ivr:02 has joined, contact <sip:[email protected]:5483/UDP>
11.03.2021 14:17:21 - L:2201.2[Ivr:02] has joined to L:2201.1[Line:10000<<0151....]
11.03.2021 14:17:21 - [CM503002]: Call(C:2201): Alerting Ivr:02 by contact <sip:[email protected]:5483/UDP>
11.03.2021 14:17:21 - [CM503025]: Call(C:2201): Calling T:Ivr:02@[Dev:sip:[email protected]:5483;rinstance=c1ea68b4285f6f8c] for L:2201.1[Line:10000<<0151.....]
But then the extension 31 (which is not the correct extension) get the call:
11.03.2021 14:17:45 - [CM503025]: Call(C:2201): Calling T:Extn:31@[Dev:sip:[email protected]:5060;line=20965] for L:2201.1[Line:10000<<0151....]
11.03.2021 14:17:45 - [Flow] Call(C:2201): has built target endpoint: Extn:31 for call from L:2201.1[Line:10000<<0151....]
11.03.2021 14:17:45 - [CM503010]: Call(C:2201): Making route(s) from Line:10000<<0151.... to <sip:[email protected]:5060/UDP>
I cannot understand why the ivr forwards to extension 31. The extension 22 is set in the IVR.
Any ideas why this happens?
regards, Betei
The IVR has joined:
regards, Betei
