Keypad is greyed out in a call
SelfDesigner
Hi there, We're using 16.0.1 on our production system and I have started to get reports that the Keypad is not accessible in the middle of a call making it difficult for our users to get past the recipients Digital Receptionist. Would anyone know how to make this work again?
Thanks.
Can you please tell us in which scenario this happens and with what browser?
Thanks for the reply. On Incoming and Outgoing calls (even Extension to Extension) this problem occurs. I see it personally on Firefox (66+67) however not on Chrome 74. I'll try to go back and check Firefox 65, This at one point was working!
Please note that only Chrome is officially supported for the WebClient.
Firefox could also work, but there may unexpected behavior like with the case you noted above.
I see the notification on the login screen re Chrome supported only, however I don't feel a couple dozen of my users are able to see that. I think they see the login page and enter the fields required and blindly click enter without reading any of the other things.
Aren't able to see it? or Aren't able to read it?
Problem definitely exists between Keyboard and Chair. Let's call it Selective reading :)
gmacinit
