- Joined
- Jan 7, 2023
- Messages
- 4
- Reaction score
- 0
In order to improve that, you would need to create a custom SIP client, where you can control all the details of what you do. Not a simple task at all. Not sure how important this is in order to invest a lot of effort on that....Out of our software a number is supplied to 3cx.... that should be called directly out of server (so not through the 3cx apps).
Speed is essential in this proces to reach the customer first. (i am looking for 1 second improvement).
Calling the extension 100 and putting it on hold is something you could do using the same approach (Make Call), and calling a shared parking extension. However, you can't merge both calls later. Instead, I would make the call to the external number, and as soon as the call is answered you connect it to your extension. Actually, this is something you can also do with SIP Caller: add the number to call using a REST API, and once the external party answers you can transfer the call to extension 100, which would have the auto-answer, so you would speak with your customer as soon as they pick up. The blind call transfer is an operation that has barely no delay.Besides that:
I want another line to call my 3cx extension 100, where i will put my desktop 3cx app in autoanswer.
This line should be on hold till the first line picks up.
Then i want to take over the line that was connected to my cutstomer.
"In order to improve that, you would need to create a custom SIP client, where you can control all the details of what you do. Not a simple task at all. Not sure how important this is in order to invest a lot of effort on that...."In order to improve that, you would need to create a custom SIP client, where you can control all the details of what you do. Not a simple task at all. Not sure how important this is in order to invest a lot of effort on that....
You will need a software developer with experience with SIP & RTP protocols. I don't know anyone to recommend on this...this is what i need, so yes it;s important. Do you know anyone who can fix this?
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
