Latest 3CX App for Android Beta Improves Call Functionality and Caller Identification
nb
Support Team
The latest 3CX App for Android Beta is jam-packed full of fixes and improvements following your feedback. Do try it out and let us know what you think.
Improved Call Functionality​
Did you encounter a request failed error message when making or answering a call? This happened whenever the network tab was changed from IP Address ...
Just playing with the video in the app, It works between the smartphone app and the web client but not with my Fanvil i18s video door phone or my Fanvil x6 and x7 phones?
Both the door phone and the desk phones use the H264 codecs. is there a way to get this to work?
If not hopefully this will be added at some stage :)
Reactions: jed
I would like to ask you why the maximum ad-hoc conference participants is set to 3? I cannot understand the reason behind it. Will that limitation goes to 3CX web client or hosting an ad-hoc conference from a IP Phone by using 700**EXT?
Please, any chance to come Back "Groups" in Presence Menu? We have a lot of Clients with more Brand Offices without Bridges (are with VPN and a only one Instance), but each Branch Office had a Group.
It's Very confusing only with names.
Maybe any Ideas or workaround?
I'm hearing that the new version does not work with v15.5. Anyone else run into this?
There are a Link to the Old version, V 15.5 only works with the old App.
Looks like the 'Exit - Ignore Push' is back in the beta? I had it for a while, but looks like the prod version has automatically updated over the beta. Without it, or some way to completely exit, this app is unusable. Thanks for listening ;)
@stalley - what a complete exaggeration. Exit without push has been replaced by silent option and the ability to disable push based on profile. (you can choose what you prefer or even both)
So the only thing compared to Exit without push is that the app will come to the front - silently - so I dont really see an issue. Advantage of the new method though is that it will not do so outside of office hours - automatically - even if you have forgotten to Exit without push. You can also use one of the other profiles to create a "No Push" profile if you so wish. You can even assign the no push option to the available profile so that an incoming call will not ring on your mobile, unless its open in front of you. So you can use the app for outbound calls only. So overall its much better.
IOS users, all 500K+ of them, never had this option and were using it quite happily. Soon they will have the above options as well so iOS users get new functionality.
As already explained Exit without PUSH is not compatible with our architecture or in fact Googles Push policies and architecture. Therefore it was not reliable across installs and android devices. So its not gonna change - please get used it.
stauag
