- Joined
- Apr 26, 2020
- Messages
- 4
- Reaction score
- 0
Hello All,
This is my first time posting here, I am hoping you can help me...
We are running a few FreePBX servers and started testing the latest 3cx system, if this works we would migrate over.
We have a server at a datacenter running: 3cx version: 16.0.611 with a public IP address and configured with FQDM.
At the remote office we are testing with an Astra 55i with the recommended FW version. (This is the phones currently working with our FreePBX servers). The idea is to upgrade, but for now this is what we have.
We have set up Option 66 on the office Dream Machine PRO and we see the phone getting the correct DHCP options from the DHCP server, whenever we navigate on the phones settings into the HTTP settings, they are there pointing to the provisioning URL that 3cx server provided us when creating the extension.
On the office local pc we tested the connectivity to the 3cx server from the command prompt we run:
telnet server ip 5000
and the server responds, meaning there isn't any firewall blocking the connection to port 5000.
I also unchecked under extension -> options: "Disallow use of extension outside the LAN (Remote extensions using Direct SIP or STUN will be blocked)"
Any ideas as to why our phones are not registering? Also does this have a cli like the asterisk on freepbx? Or is it all GUI based?
Thank you in advanced for any suggestions.
