License Downgrade/System Archive Question
2cx-novice
Hi. We have v18 running with an Enterprise License and 32 Sim calls with an annual license.
The license is due to expire soon.
We are moving off this platform, but have a lot of recorded calls and other things we might want to keep on hand, but not necessarily have actively running.
What happens when the license expires?
If 3cx bricks when the license expires, can I buy a cheaper license to put on the system so we can fire this up and access the archived recordings etc. if needed?
Or, any other suggestions?
Thank you!
Couldnt say.. you should be able to replace your license if it expires but it depends how long down the line you do that.. things could change. You'd be better off just making sure you have access to your wav files.
Just download your recordings to somewhere else...
You can downgrade at renewal to a 4SC and you will still have access to all the recordings since 3CX does not care about the number of users (thus recordings).
Reactions: 2cx-novice
x1515
