License Key location
NathanD1337
Hi, Does anyone know where the actual license key location is via ssh.
I'm creating a script to extract the expiry date of the license to create an alert on our monitoring system when its up for renewal in x amount of days but I'm struggling to find the exact location of the file.
Thanks.
I doubt its in a file, it's likely in the DB itself.
3CX emails alerts pre-expiration - why not just use that as a reminder? Also a customer likely has only a few systems - it's the same date every year - why not configure your monitoring manually once?
Yeah i've found it in the DB but cant find the expiry anywhere and reason behind it is we have over 50+vms so emails can get missed so its just easier if we can get it pushed through the monitoring system.
Ah, so more of a partner type situation. @BrenttG or @VoIPTools might have some insight on pulling the expiration programmatically.
You can gather the expiry date via the API with some quick reverse engineering.
A GET request to /api/SystemStatus will get you a lot of information, including the license expiration date.
But first, you need to get a token through a POST to /api/login with a json body containing the Username and Password fields.
WinSip
