Lines are cutting
Ely1
Hello
Appreciate if you can help us. Most of our calls are being disconnected after 4 to 5seconds. This is happening approximately every day.
Any idea what could be the issue.
thanks.
Hello @VasilisV_3CX
Please find my comments below:
  • 3CX Version Enterprise Annual 16.0.8.9
  • Server OS, Debian 9
  • Is the 3CX Server Hosted and where? Azure
  • IP Phone Make/Model/Firmware version, No IP phones only Windows 3cx app
  • Provisioning Method:SBC
  • Trunk Provider or VoIP Gateway Make/Model, Grandstream GXW4104
  • Has the Firewall Checker passed: Yes
  • Are custom Phone Templates being used: No
Thank you.
Hi @Ely1,
Does this happen with internal calls? External Calls?
Could you clarify a couple things, are you using a FXO gateway with a cloud installation as this isn't supported?
Also the SBC, if you're only using the 3CX Windows App, why use the SBC?
Hello @VasilisV_3CX
it happens with the internal & external calls
SBC because they have physical phones in addition to the 3cx apps
Hi @Ely1,
Firstly I must remind you that the Grandstream GXW4104 is not a supported model when you're not local to the PBX.
If you call from 3CX App to *777, does the call drop after 5 seconds?
If no, call from Ext A to Ext B, does that drop after 5 seconds as well?
If both scenarios drop the call after 5 seconds, can you create 2 fresh extensions on the PBX and send me the log in details via PM?
WagnerFT
