Linux ISO - 3CX Configuration
james_tech
Using the latest iso you should have ended up there. I suggest you try to redeploy it again from scratch.
I was using the latest ISO, turns out it was Geo-Location on the Firewall blocking it. For some reason it goes to the USA :)
Reactions: JohnS_3CX
