Local RTP Port Range Setting for Yealink T46S
pcmis
Hello What is the Local RTP Port Range Setting supposed to be set at for a Yealink T46S (firmware 66.83.0.55) ?
The 3CX version I am using is Professional 15.5.15502.6
This is the phone default (11780-12780)...but not sure if I am supposed to change it to the 9000-10999 or something else.
9877
These numbers are correct.
How are you provisioning the T46S, as all the correct settings are provided by the provisioning file
thanks. I was provisioning manually.
Is it required to use auto provisioning?
Not an absolute requirement, but why wouldn't you if you consider:
  • Time saving.
  • If you reset the phone with auto-provisioning it will re-provision again.
I just setup an auto provision and it seems to be working. I will try moving forward. thanks!
supuni_rathnayake
