Locked out of Yealink Panel.
JerS
Hi Guys! I provisoned my phone and i like to edit things from the yealink panel. Normal you can get in with admin/admin this wont work.
There is another popup (only white) when i open my phone ip.
What can i do so i get in?
RESET DONT WORK!
If you have provisioned the phone, the web password is changed.
Under the 'Phone Provisioning' Tab you will see
Click on the the eye to the right and this is the new web gui password
What are you editing on the phone, as these maybe wiped next time the phone provisions which is every 24 hrs.
You said reset did not work - this means that while the phone is not yet provisioned, you still cannot get in with admin/admin. This means the phone has not been provisioned by 3CX
It has to get the password from somewhere. If not by 3CX, then your phone is most likely remotely managed by a 3rd party service.
Stephan Eusebe
