Shua Free User Joined Dec 18, 2022 Messages 7 Reaction score 0 Dec 18, 2022 #1 Trying to login to the PBX getting error "Login access denied. Too many incorrect login attempts. Try later or contact the Administrator." please advise
leejor Customer Joined Jan 22, 2008 Messages 16,670 Reaction score 1,658 Dec 18, 2022 #2 Sounds as if you are attempting to use incorrect credentials. What type of 3CX install are you using? See... https://www.3cx.com/blog/docs/pbx-security-checkup/
DimitrisL_3CX Staff member Joined May 13, 2021 Messages 281 Reaction score 222 Dec 18, 2022 #3 Hello @Shua, I noticed that you own two licenses, one is StartUp and the other one is Hosted dedicated. Can you please send me a private message with the license key information so I can check this further?
Shua Free User Joined Dec 18, 2022 Messages 7 Reaction score 0 Dec 23, 2022 #4 I established to log in from another network, thank you the solution was to use the hot spot from the cell and access it again, then go to blacklist and remove my public IP
