Login loop
ea5522
After a power outage and some issues with time, cannot login to 3cx web interface. It keeps on looping back to login screen. What could be the issue? I'm running v20 on windows server 2022
Check services are started.
Are you logging in with SSO or native extension and pw?
Can you try in private browsing.
Are you trying from the server or a PC?
Try clearing the browser cache and see if that makes any change.
