Logs not "working" after update to v18 (service still works)
nbabucks1
Logs were working fine before. Only things that happened were the AWS instance of 3cx changed it's ip (I have since added a static IP in AWS and assigned that in networking.) and we have updated to version 18.
Want to reiterate that all calls and transfers work fine.
Any idea what I need to do to fix this?
Hopefully I marked out anything personal.
Hi @nbabucks1,
Can you describe what is not working within the logs? What should you be seeing that you're not?
The previous logs I had did not show 'errors' like these do. Almost every log there is an 'error' (loose definition). Doesn't show successful calls, doesn't show transfers, etc.
I don't have any for reference unfortunately.
You should be able see more information if you increase the logging level.
RemyDijke
