Solved Lost access to my system- Can I restore settings or transfer my license
AceDog
I made a newbie mistake. I'm running a system hosted with 3CX. Set up and everything was running fine. I paid for a pro license so that I can integrate with Hubspot and that was working fine. Then I downloaded what I thought was the Windows app but must of been the v18 self hosted installer. It started to ask me a lot of configuration questions that didn't make sense so I closed it down. Now my link to my web client doesn't work. I received an email that the IP address was changed. (Probably when I did the install of the software on Windows).
  1. Is there a way I can change the IP back to the 3CX hosted version?
  2. If not, is there a procedure to create a new service and transfer the license?
Unfortunately I had not setup backups yet
@AceDog clear your local dns cache and check again.
I rebinded the fqdn with your hosted instance.
If you installed it at your pc remove the hosts files of the pbx.
Thanks Nikos T. Yes now it is back and working. I really appreciate it.
Reactions: NikosT_3CX
