Solved Lost call log
RDWild
I have a user who is set up as a system administrator, and has the "Monitor (Has access to reports, chat logs, call logs & recordings)" option checked, but sometime over the past few days, the option is no longer there for him. Under reporting he only has one choice, $ CDR
Are you in V18 or V20?
Just to clarify, the issue is that this option is being disabled?
If so have you checked the audit log for any changes?
Well, the option to view logs is enabled, but the option just isn't there under the management console.
Is the user member of multiple groups?
We only have the default group. Unless you also include ring groups, he is a member of 2 of those.
If you elevate to "Manager" are you able to see the reports?
Thank you, that did it
Glad to know this is resolved ;)
/dev/simon
