Lumen SIP Trunk question.
iwcb002
I was looking and Centurylink is listed as a SIP provider, but in the area they are going by Lumen now. Is Lumen then a supported provider for a Locally Hosted 3cx system? Thanks.
If it's not supported, are you in a position to change?
Hi @iwcb002
Lumen and CenturyLink are the same thing. The trunks are the same and are still supported.
Reactions: iwcb002
Thanks. I'll see if they will give the option then to switch the lines over.
Reactions: YiannisH_3CX
Senergia
