Solved mail settings
Mfh
I have the system setup to email voice messages to people and delete. I can't find where to change the from email and settings?
All the information I found is for older syste4ms and do not exist in the new version - I am Running 18.0 (Build 461)
Settings/Email :)
That is for notifications- i want the setting for when you have the voicemail option to send the message from the voicemail to the customer
As a separate/second From address? I don't recall seeing that in v16, and am not aware of a separate setting in v18.
Are you perhaps referring to the From Display name? If yes you should be able to do this from "Settings >> Email >> Email Templates":
Note: To be able to change this you must not be using the 3CX SMTP in "Settings >> Email".
If you want to change the actual from email then again, you would need to use a custom SMTP.
That's it thanks for all the help
Reactions: NickD_3CX
mazet
