That depends. If all the blocked numbers start with 01234 you could put that in the prefix with length of 10 and all of these would be blocked in a single rule:no word to say, just thank you guys,
it means that I need to create for each number a new rule!
I don't see how you can force outbound calls through a CFD.numbers are different.. Maybe the The 3CX Call Flow Designer (CFD) is the solution:
to create a dynamic (json) file-list with all numbers so every call can pass thought that filter and then make calls!!
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
