Make a Universal Bridge
Ahoudou_njikam
I have two different IPBX, 3cx and Panasonic RX-TDE600. I need to make Bridge between this two IPBX. 3cx is use for external call and Panasonic for internal call.
In this bridge, I want that the use of 3cx can call the user of Panasonic and can make transfer call thought this bridge.
If the Panasonic is able to register a SIP trunk to 3CX, then it might work.
See this link, to some old information, that you might use, about creating a Bridge trunk to an Asterisk PBX...
https://web.archive.org/web/20161213151353/http://www.3cx.com/docs/bridging-asterisk-pbx/
Keep in mind that bridging to a second PBX, that is not 3CX, is no longer supported. You may end up pulling out all of your hair trying to get this to work, and some things, such as caller ID, may never work as desired. You will also have to work out the call routing at both ends.
You are warned, good luck.
Silent_Guru
