Solved Making Extension Length shorter
AcksiosKim
I just started to play around 3cx for my company.
Is it possibile for me to extension the length from 5 to 3 with a client subscription?
Acksios Kim
For the SMB installations this is not an option.
Reactions: NikolasA_3CX
Aside from the specific restrictions on SMB installations, you specify the number of digits desired (2-5) and this cannot be changed later. If you needed, for example, to change from 3 digit extensions to 2 digit extensions, you would have to start over from scratch with a new installation and manually recreate users, queues, IVRs, etc.
Thanks, Would it be possible for me to change the extension number? for example, the current extension is 27911. I would like it to be 10011, 10012... is this possible? If it is would you be able to point me in the right direction to learn? :) thank you.
I'm afraid not as for each SMB installation there is a specific range that is allowed.
You are welcome ;)
Jake_Southern
