Solved Management Console in Version 20
siscom
Good Morning Colleagues
I hope you are doing well . In version 18 , when login to webclient then to admin , You can find a button in the left menu named "M.Console" (as per the first snapshot). When you click on it , You will be redirected to classic Management console.
In version 20 , I can't find this button (as per the second snapshot).
May i know where can i find this button or similar one that can redirect me to classic Management console in Version 20 ?
Best Regards
The Management Console is no longer available in Version 20. We use the Admin console in Version 20.
This is the reason we require a System Owner extension during the migration from Version 18 to Version 20, as now all the administration is done via the extensions login.
Thanks for your replay
Reactions: NicholasP_3CX
youwillbrun
