Management Console logging
Comsave
Hi all!
I was wondering if there is a possibility to be able to find in the logs when an extension with management console access has logged into the management console and also when this extension performed actions/changes?
Thanks in advance!
Kind regards,
Brian
Hello @Comsave
Unfortunately a audit log is currently not available in 3CX so you cannot track changes made. You can enable a notification however that will send you an email every time a user logs in to the management console. You can enable it under Settings / Email / Notifications / "Log in to 3CX Management console "
Hi YiannisH!
Thanks for your quick reply! I do hope to see that fuction comming on in the future then, for now I'll use the log in notifications. Thank you
Reactions: YiannisH_3CX
fransisco
