Management Interface - Login Error when 3CX server is on specific VLAN
rogan
I've got a strange (likely Firewall) issue - I've setup our test 3CX server and can access management console on 5000 and 5001 without issues when in the development vlan.
After moving the server to it's intended separate vlan I can see it come up on the correct IP, I can browse to the management console on 5000 and 5001 however I cannot login.
The screen sits on "Loading..." for longer than usual and once loaded I enter username and password (if incorrect it tells me) and then after a minute or so (timeout duration) it gives a very generic "Server Error" message in red above the login box.
Any theories as to what ports this means I'm missing? Given I can browse and telnet on 5000 and 5001 to the box I'd have assumed I could login...
Moving back to other vlan and rebooting the unit is accessible and works fine.
Additional info - Debian ISO install hosted locally in VMware, not resolved by restart, all services running correctly, nothing obvious in the logs I've looked at.
Have confirmed there is no firewalling between my desktop and this server - It is on a different subnet, is there some NGINX config that may be affecting this?
Can you put your desktop on the same (intended) VLAN as the PBX server?
If not - may be client related - try different browser/in-private etc
If so, may be firewall related, had a "similar" issue the other day moving a windows host to a different VLAN and some things stopped working, and it was the scope on the firewall set to "local subnet only" - and as VLAN was a different range (fully routed) it got missed. (192.168.1.x & 192.168.2.x).
Are you specifying that VM onto a specific virtual network which is tagged on the vmware host, or are you moving the vmware host as a whole to another vlan?
VLAN config on vmware can be tricky, you may have a config issue there.
hughesdouglas
