Solved ManagementConso crash regularly when extension is added
Lukas Sukdol
after fresh install Debian/3cx PBX v15.5 on minicomp Zotac Zbox CI327 Nano (Celeron N3450, 8GB RAM), I am facing next failure - when new extension is created in Management Console, service 3CXPhoneSystemMC01 crash immediately, with error message on stdout (and dmesg):
traps: ManagementConso[835] trap invalid opcode ip:7f8c0b2b3914 sp:7f8af77a93f0 error:0
in libcoreclr.so[7f8c0b025000+39f000]
Despite of this failure, extension is created and saved, after service restart (service 3CXPhoneSystemMC01 restart) I am able to use it, change it, save again - without any failure...
Same failure could be produced by clicking Terminal link on Dashboard - when I close the terminal Tab (Chrome 65.0 and Safari 11.0 on Mac 10.12.6) service 3CXPhoneSystemMC01 also crash immediately...
Any idea?
Thanks @YiannisH_3CX
So the only workaround for me is to create extensions with hands on the server keyboard ...
This is because .net core from microsoft does not support all the extensions for your current CPU.
This will be fixed in SP5.
If you want a build that fixes this, contact me via pm. But then when the actual release is out, you will need run some commands to go back to production. IF you are ok with this contact me. If not, then keep on creating the extension and ignore this error (because technically you can still proceed) or import extensions and wait for SP5. This will be released in a months time.
@nb - thanks for the idea to use import - seems to be pretty straightforward to use csv import/export
Yes - good - use import feature - add all your extensions at one go.
Restart the service one time after import to ensure that none of the data is corrupted.
Work as it is for now, and soon sp5 will be out and you can add extensions at will on this mini pc with no problems.
Please, tell us. We have issues with SP2 and Fanvil provisioning. On SP4 the problem is solved but we cannot upgrade beacause of this DOT NET issue. How can i send you a PM ?
