True I captured the wrong license pic I have since erased the pic that was the working one smh. So your saying I'm on a Alpha version (V16.0.5.454 ) and need to downgrade ? Also thanks for your responseHi what is the right release you run?
in top of your post you wrote about V16 SP5 and capture is from SP4 ? so which one is the good one running?
IF SP5 this is not a release to use in production as it is Alpha version for now.
Understood. I'm showing 16.0.5.507 available now. Would this update be considered to be a "stable" version?You can't downgrade, now you need to wait until SP5 become the stable release for production.
Most surely the only way to step back is to reinstall with backup from V16 SP4, but if you have no real important problem then best is wait until SP5 become brodcasted as production release
That was most definitely my issue THANK YOU!!!!So Tony is the Manager of the DEFAULT group and you've sent a screenshot of a group called Belmont All
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
