Manual certificate renewal
JC_AU
My certificate for the portal on port 5001 has expired and doesn't appear to be renewing. I suspect it's because I don't have port 80 or 443 forwarding to the 3CX server (not sure the manual actually says you need this) and I'm pretty sure letsencrypt requires port 80. I've opened it up and want to force the renewal but can't find what client 3CX uses. How do I manually renew from the console?
Cheers,
Justin.
You do not need port 80 or 443 forwarded to your 3CX server.
What are your dns settings on the server , change to google 8.8.8.8 and restart your server.
There is no way of updating via the console.
Wecare_ITA
