Solved Manual SSL renewal
Connexium
I am using the latest 3cx version (16.0.3.676) on my own Google Cloud account. It was installed by the PBX Express.
  1. I made a mistake and had to revert to an old snapshot from may 2019. #youshouldenabledeletionprotection
  2. I updated the PBX to the latest version.
  3. Then was able to restore all the settings from a fresh (last night) 3cx backup from my Google Drive after re-updating the PBX to the latest version to match the backup version.
Now I am stuck with the old SSL certificate for my Web Login. It was automatically updated last week (its every 3 months right)?
Now:
Chrome wont allow me to log in my PBX period. NET::ERR_CERT_DATE_INVALID
Firefox wil,l with an exception
Is there anyway I can trigger a SSL refresh?
Any other problem I might encounter with an invalid SSL?
Your assistance is greatly appreciated.
Well it seems that the SSL fairy came and delivered a new certificate under my pillow about an hour ago. Its a relief.
Reactions: JohnS_3CX
The system will update the certificates automatically, as you have just discovered :)
Kayla Norris
