Manually configure W52p
DaveySmo
Hi all,
As I can no longer add a W52p via the management portal how do I add it manually?
The guide states ( https://www.3cx.com/sip-phones/yealink-dect-w52p/ ) to add it then further down to enter the authentication ID - but as I cant it via the portal how can I add this? Am I just missing something simple here?
Thanks for any assistance.
Kind regards,
David.
solved - I simply added the credentials from the extension.
SupportRock
