Mapping does not match 5060
eng5ald
we have this issue
we installed 3cx in Debian server and we have this issue
please we need your help
Reactions: JohnS_3CX
Hi @eng5ald
You firewall (or ISP modem) must be configured correctly as stated above by the other forum members.
If you do not configure it (Port Forwarding) then it will automatically assign any port it wants to your PBX traffic. Try to setup your ports following the links by @eddv123 and @Clément Rousseau and when you are done run the firewall checker again to check your progress.
We need Full-cone NAT if you want to look it up online.
we are using FortiGate 800D and we make the forwarding configuration but still give me the same error
we need to make reboot for 3cx system after making the configuration in the local firewall
The FortiGate should be rebooted after the changes
travislogixal
