Maximizer CRM Integration
hmknc
Forum User
I've been searching the forum for any references of people using Maximizer with 3CX but can't seem to find anything. Has anyone managed to use the 3CX API to link with Maximizer, either on premise version or Maximizer Live hosted version?
As the latest versions of Maximizer are browser based, we can use click to call for dial out but wanted to pop contact information for incoming calls. The documentation for the Maximizer API is not great so before we start to spend any significant time trying to integrate 3CX and Maximizer, I wanted to know if anyone had managed to achieve this successfully?
If they have a REST API, you can create the integration by following this guide:
https://www.3cx.com/docs/crm-integration/
Maximizer provide a web services API rather than a RESTful API so not sure that method will work. I was hoping that someone else had successfully integrated Maximizer with 3CX so that I don't have to reinvent the wheel.
costionofrei
