Maximum Size for Backup
Rodolfo Olvera V
I'm working on reinstalling my 3CX on a new server, but wondering what is the maximum size allowed for a backup using the web installation?
Hello Rodolfo Olvera V,
There is no known limitations for 3CX Backup size. When you perform backup, make sure your server have enough storage.
If your backup size is too big then the restoration process will be delayed. I would recommend in case the backup file is very large, that you do it without the recordings and import them later.
I did restores 3cx backup files between 4 - 6GB on Windows machines.
As Naveen | Cal4care mentioned, there is no specific limit, however, if you are facing issues you might want to instead consider using the CLI installation wizard which entails moving the backup to the server beforehand.
laranicole.lucus
