May I bridge 2 Startup instances together?
k.lee
Forum User
Sorry I need to ask the question here because I haven't created a Startup instance just yet.
If I want to try and learn about bridging 2 3CX instances together, may I apply for 2 StartUp instances and try the bridging configurations?
Alternative may I apply for 2 Startup instances and manually create pseudo SIP trunks with the appropriate outbound rules that connect to VOIP extensions on each side of the Startup instances to emulate bridging?
thx
kenneth
Bridges are not available for 3CX StartUP.
As far as manually creating your own "pseudo SIP trunks " it is not possible.
Only supported VoIP providers are available using their template.
You are welcome.
Glad I could clarify this for you!
ARKC
