Media Ports Random Full Cone Failure
ycit.ash
Trainee Partner
I have searched something exactly what I am experiencing but have not found it.
I have all required ports open and all ports are statically mapped when running firewall check most ports pass with no error. The issue is that a lot of random ports in the 9000-10999 range fail. Most seem to pass with the normal 'done' in green, but a bunch fail with the 'full cone test failure' error. All of the previous tests pass.
I have tried packet sniffing to find the issue, but the output is incomplete not showing all the ports in the range. I am using pfSense 2.4.4p3. The pfSense was a VM, but I have switched it to a physical box and I seem to be having slightly better performance on the physical box, but the 3CX FW Test still fails random ports in the 9000-10999 range.
Here is the text output of the tested ports...
  • Code:
    resolving 'stun-us.3cx.com'... done
    resolving 'stun2.3cx.com'... done
    resolving 'stun3.3cx.com'... done
    resolving 'sip-alg-detector.3cx.com'... done
    testing 3CX SIP Server... done
    stopping service... done
    detecting SIP ALG... not detected
    testing port 5060... done
    starting service... done
    testing 3CX Tunneling Proxy... done
    testing port 5090... done
    testing 3CX Media Server... failed (How to resolve?)
    testing ports [9000..9398]... failed (How to resolve?)
    testing port 9000... done
    testing port 9002... done
    testing port 9004... done
    testing port 9006... done
    testing port 9008... done
    testing port 9010... done
    testing port 9012... done
    testing port 9014... done
    testing port 9016... done
    testing port 9018... full cone test failed (How to resolve?)
    testing port 9020... done
    testing port 9022... full cone test failed (How to resolve?)
    testing port 9024... done
    testing port 9026... done
    testing port 9028... done
    testing port 9030... done
    testing port 9032... full cone test failed (How to resolve?)
    testing port 9034... done
    testing port 9036... done
    testing port 9038... full cone test failed (How to resolve?)
    testing port 9040... full cone test failed (How to resolve?)
    testing port 9042... done
    testing port 9044... full cone test failed (How to resolve?)
    testing port 9046... done
    testing port 9048... done
    testing port 9050... done
    testing port 9052... done
    testing port 9054... done
    testing port 9056... done
    testing port 9058... done
    testing port 9060... done
    testing port 9062... done
    testing port 9064... done
    testing port 9066... done
    testing port 9068... done
    testing port 9070... full cone test failed (How to resolve?)
    testing port 9072... done
    testing port 9074... done
    testing port 9076... done
    testing port 9078... done
    testing port 9080... full cone test failed (How to resolve?)
    testing port 9082... done
    testing port 9084... done
    testing port 9086... full cone test failed (How to resolve?)
    testing port 9088... done
    testing port 9090... done
    testing port 9092... done
    testing port 9094... done
    testing port 9096... done
    testing port 9098... done
    testing port 9100... done
    testing port 9102... done
    testing port 9104... full cone test failed (How to resolve?)
    testing port 9106... done
    testing port 9108... done
    testing port 9110... full cone test failed (How to resolve?)
    testing port 9112... done
    testing port 9114... full cone test failed (How to resolve?)
    testing port 9116... done
    testing port 9118... full cone test failed (How to resolve?)
    testing port 9120... full cone test failed (How to resolve?)
    testing port 9122... done
    testing port 9124... done
    testing port 9126... full cone test failed (How to resolve?)
    testing port 9128... done
    testing port 9130... done
    testing port 9132... done
    testing port 9134... done
    testing port 9136... done
    testing port 9138... full cone test failed (How to resolve?)
    testing port 9140... done
    testing port 9142... done
    testing port 9144... done
    testing port 9146... done
    testing port 9148... done
    testing port 9150... done
    testing port 9152... done
    testing port 9154... done
    testing port 9156... done
    testing port 9158... done
    testing port 9160... done
    testing port 9162... full cone test failed (How to resolve?)
    testing port 9164... done
    testing port 9166... done
    testing port 9168... done
    testing port 9170... full cone test failed (How to resolve?)
    testing port 9172... full cone test failed (How to resolve?)
    testing port 9174... done
    testing port 9176... done
    testing port 9178... done
    testing port 9180... full cone test failed (How to resolve?)
    testing port 9182... done
    testing port 9184... full cone test failed (How to resolve?)
    testing port 9186... done
    testing port 9188... full cone test failed (How to resolve?)
    testing port 9190... done
    (output cut due to character limit on post.)
Mr_IT
