Solved Memory usage with hosted 3cx
Bruce Fox
I have a system I have done up hosted in AWS Lightsail 1 GB RAM, 1 vCPU, 40 GB SSD
The system only has around 8 extensions and has very modest usage throughout the day.
The system seems to have a very high memory usage > 70%
We are using version 18 at the moment on a free 8 user license
The activity log is set to low and there are only 5 handsets registered against the system.
Would you be able to offer any explanation as to whey the memory usage is so high?
I would like to mention that for a cloud 3CX Instance hosted in AWS LightSail we actually recommend a t2.small instance which, if I am not mistaken, has 1 vCPU and 2 GB of RAM:
Provided that the usage will drop from 70% to approximately 35%, I would say that memory usage would be normal in this case.
Thankyou and noted.
Reactions: VasilisV_3CX
Feel free to open a new thread if you require anything else @Bruce Fox.
Mr_IT
