Solved Microsoft 365 integration module not in settings
bbeeken
New User
Hello everyone - I have an issue where I have a hosted instance with an enterprise license and the 365 integration option in settings is simply not there. All of the guides I find in regards to integration say I need to go there first but I can't and I am just stuck. I rebooted the instance, I am just not sure where to go from here. Any ideas?
@bbeeken are you sure you are on the correct PBX ? Because I can see that you are on the correct version and this should be next to Hotel Services. What browser are you using ? Ensure you use Chrome please.
I am on the right server, it is the only one I have. I used Edge and Chrome on 2 different computers and it isn't there.
@bbeeken create a test extension with full admin rights and PM me the credentials please.
I want to take a look on your PBX please if thats ok with you..
Then after tshoot you can delete this extension totally.
Can you please reload the subscription from the dashboard. Let me know if this brings the option back?
I did reload the subscription it did not help.
Got it solved, my fault. I was logged in with an extension with admin rights, but not the default admin user itself. i did that and was able to see the 365 and google integration options. Thanks everyone
devo.it
