Migrate 3CX server need new register?
TecnologiaMatrix
Hi, I need to migrate my 3CX Server to other server with newer SO, different private IP address and hostname, but the public name and IP address continued the same.
So my question is if I need to register the license again or I need only to make the install and restore process, can you help me please?
Thank you.
Hello
Then just take a full backup of your 3CX, shutdown the "old" 3CX and then install your new instance, restoring the full backup, et voilà!
Hello
Thank you for answer.
So I don't need to make anything about licensing, correct?
nope, it will be reimported with the backup, and binded to the new instance !
The above, but note a Pro license has a 6 hour TTL on a 3CX-domain hostname. Enterprise is 5 minutes.
Same public IP though, so shouldn't matter.
If you will still use the same FQDN this is a straight forward process with backup/restore.
Reactions: TecnologiaMatrix
Ahzaz
