migrate fqdn.my3cx.com to own fqdn ?
Especialistas
Hello, I'd like to know how can I migrate to own fqdn on 3CX running ?
Thank you so much
Please note that to change FQDN, you must re-install the system. To do so:
  • Create a backup of the system without license and FQDN information
  • Un-install the PBX
  • Access the customer portal and release the key from the current FQDN
  • Re-install the system using the license key and your own FQDN.
Please note that you must also provide a certificate for your FQDN and that custom FQDNs can only be used with a PRO or Enterprise edition key.
mazet
