Migrate from azure to onpremise
bennuss
Forum User
I want to migrate from my azure install (enterprise ) to an on site linux install. I spun up the custom linux vm . I have a dedicated wan ip for the system behind a firewall. Do i just do a full restore from the azure ? I set the azure install to dynamic ip so it should pick up the new external ip. Which ports do i have to forward if i want to access the system directly offsite.
Do a full backup of the existing 3CX server including FQDN and license key - copy this file locally as it will be required.
Switch off the Azure instance as you can not have two 3CX with the same license key running at the same time,
Install 3CX on the new VM, and select restore from backup when running the 3CX wizard
As above, you will have to change all your physical phones to Lan setup - instead of SIP / SBC
Wecare_ITA
