Migrating 3CX Raspberry Pi (v18U2) to Debian VM
jamesf
I missed the notification that in addition to needing Version 18 update 5 past November 30, 2022, that Raspberry Pi servers were EOL and won't get the update. Is the process of backup\restoration to an X86\64 3CX Debian install straightforward, or will the numerous updates released since than cause any issues? Will the backup\restore set the same static IP as the old server, or is it recommended to use a new static IP internally and update firewall rules? If anything goes wrong with the restore (like desk phones don't reprovision), I assume I can just turn off the new version and continue running on RPI until I find the solution? The phones still work but the SSL update means that the FQDN doesn't resolve externally.
Do SIP settings come across in 3CX restores?
All settings come over. Ideally shut down the RPi and give the Debian VM the same local static IP that it was using so that the local phones don't have to be re-configured.
Reactions: jamesf
Thanks.
grahamaskew
