migrating my PBX to google cloud
slanec73
Hi, i got a problem with migrating my PBX to google cloud. I just does everything by your guide, but there is a problem with google cloud allowing to create instance ..... It says : "You should allow this application to access to Google Cloud" ....... So Where can i verify that functionality ? Thanks a lot
Are you using PBXExpress or the GCP Marketplace image?
you probably forgot a step in the process, have you created a google cloud account before starting pbx express?
what do you expect when you say migrating my pbx to google cloud?
Pbx express is just a tool for creation of new instance and automated 3cx install, but you need to restore your config if you want to retrieve your previous working pbx
Create a google cloud account with ssh key and all the stuff first.
Then use pbx-express to restore it with your backup file !
fcentral
