Mikrotik 3cx configuration
3cxetadmin
Hi everyone, I am having problem with configruation please can somone advise or help me
I am having problem with 3cx firewall,
How to fix them
Current configuration on nat
You also need to adjust your firewall filter rules to allow traffic on the required ports. Have you put those rules in yet?
Reactions: parooze and nub
How to fix them
Looks like nothing is hitting the 5060 tcp/udp rules as the counter to the right is zero. Telnet to the dst address on port 5060 and the counter should go up at least 1 packet on the tcp rule.
If you use the default firewall filter rules you are good. You don't have to change anything.
Besides the default NAT rules, add 2 NAT rules for forwarding to your 3CX:
/ip firewall nat
add action=dst-nat chain=dstnat comment="3CX Phone System" dst-port=5060,5061,5090,5001 in-interface-list=WAN protocol=tcp to-addresses=<ip-address pbx>
add action=dst-nat chain=dstnat dst-port=5060,5090,9000-10999 in-interface-list=WAN protocol=udp to-addresses=<ip-address pbx>
Do not forget to disable SIP ports:
/ip firewall service-port
set sip disabled=yes
Edvard
