Solved Minifying LiveChat Javascript?
ricksimnett
I am getting tons of SEO warnings about unminified javascript coming from https://cdn.3cx.com/livechat/v1/callus.js
Is there a minified version I can link to? If not, can I take the JS file from the CDN, minify it myself, and then load that without consequence from my phone system?
Thanks in advance.
Rick
Thanks in advance.
Rick
So I took the liberty of experimenting with this - and the answer is YES you can take that JS file minify it all the way, and host it yourself. It works perfectly!
Reactions: NickD_3CX
Hi @ricksimnett,
Thanks for your update! Glad you got this working.
Finatra.us
