Minimize All Components
sheltermanager@siskiyouhu
SOHO User
Hello, me again.
As my CFA gets larger I find it necessary to minimize components.
Even if I save the project with everything minimized, when I open the project again everything is expanded out.
In order for me to see what I am doing i start minimizing all of the components from the bottom up. I find that if I click too slow as the component collapses, cells shift, and sometimes the CFD will recognize that as a drag and drop then move components to a different part of the CFA.
My question is,
Is there a shortcut/ hotkey that minimizes all components? Or even single components when on hover or selected?
I may have missed the documentation on hotkeys in the CFD manual. Sorry if I did.
The Collapse option will only be visible when the selected items are collapsible. So you will need to select only those components having the CTRL key pressed, and then you can collapse all at once. That's the best you can do.
If it's possible use User Defined Componen to make your CFD script more manageable.
Ill have to try some standard Windows commands.
CTRL+A?
Ill give just CTRL a shot as well.
The biggest issue is the accidental moving of components when collapsing them. Then they get lost!
Ctrl+A will select all, including the inner components, and then you will not be able to collapse them at once. You must select collapsible components only.
Graham Robertson
